Borg Warner trans leak
- 650Guy
- Captain
- Been thanked: 35 times
While repairing my Generator I found my starboard Engine bay has a puddle of trans fluid in it and my transmission on that side is low. Great! Ain’t that awesome!
So I have very limited experience with Borg Warner V-Drives. Are there typical places these will leak from? In a quick search I found a couple posts about a rear seal?
So my question here is:
* can these typically be fixed in boat?
* should I be looking someplace specific for the leak? It seems that the fluid seems to be focused toward the aft end
* fixing these bad boys, is it something you should just leave to a pro, or if you have a mechanical aptitude of maybe 6 of 10, would ya tackle it yourself?
Love to learn from ya all as to what your thoughts are.
- Has thanked: 580 times
- Been thanked: 1210 times
Re: Borg Warner trans leak
- Has thanked: 324 times
- Been thanked: 595 times
As mentioned, clean it all up. Top it off and find the leak before extreme panic.
- 650Guy
- Captain
What is funny is I believe the dipstick stem is broken. So the "ring" at the top that you use to pull it out is hanging on by a thread. so just the other day I slid it out a little so I could always get ahold of SOMETHING to get it out. Man, if its popping out there, that would be like an incredibly easy find! I'm ordering a new dipstick right now!
Aha...so that dipstick has an expandable rubber at the top like a boat drain plug that you tighten by holding the ring and turning the handle at the top.....if that is not tightened then they will leak like a sieve....you can tell when you have it tight as you cannot pull it out to check the level.......the starboard will leak more because of the gear direction inside.
Just take it out and play with it to see how it works.....good catch, I am sure that is all it is.
- 650Guy
- Captain
Actually, after I was thinking about it, I THINK it was the engine OIL dipstick that is broken. Just went to order a new dipstick and realized it was the YELLOW one with the barbs, NOT the expandable one on the trans. I was prematurely excited I think. NOT to say its still not a chance, and in actuality, really hoping it is!
- 650Guy
- Captain
Anyway, I'll deal with that on another thread if need be. good times!! hahah
- Been thanked: 1043 times
If it's not leaking at a hose, drain plug, vent or shift mechanism, I doubt you could fix it on the boat. The rear seal is pressed in but you have to take the flange off to get to it. Might be possible on the boat but it would be a bear.
Also make sure it's at the right level instead of 'overfull'. Since they're at an angle, the "right" level is sometimes hard to determine with 100% accuracy, especially if a PO has changed dipsticks.
- 650Guy
- Captain
The leak was a LOT more minor than I initally thought. There is no appreciable “Drip” on the bottom side of the trany. From looking at the hull under the trans you can see a “mist” of fluid under the drive shaft, but very minor. The coupling showed no sign of fluid nor did the trans where the shaft comes out.
I may just have a situation of some fluid got dripped and as water sloshes in the bay (like all 350 mariners seem to do, carry a little water in the aft bay) it picked up the fuild. I have cleaned the entire area VERY well, dried it to the T and next time I take her out, see how it did.
I guess more to come??
Users browsing this forum: No registered users and 53 guests
