Putting in a new HVAC system, I had to disassemble the cabinetry in the aft cabin. Found out where there was a blank panel in the bottom spot of the cabinet where there were two drawers above and there's available space behind that spot.
Put a couple hinges on the bottom of the panel and put a drawer pull on it to look like the two drawers above it. The hinges are spring loaded so they will hold it shut without a latch. There's about a cubic foot of space behind there. Just need to line it with something to make it look nice now.
Here's the before:
Here's two after shots:
3607 New storage spot
