Where is the vacuum canister on my 396?
J
Where is my vacuum canister?
Re: Where is my vacuum canister?
I don't have a 396, but looked at a couple. I assume you have central vac. If you only have one inlet for the central vac, the unit is normally behind that inlet. Most often under or next to the TV cabinet.
- DanM
- Vessel Info: Carver 396
- Been thanked: 35 times
On the ES version it is under the salon TV in the back of the cabinet on the Starboard side. BTW that cabinet makes an excellent liquor cabinet. Plenty of room for plenty of bottles.
Dan
Carver 396
SugarSand Tango
Carver 396
SugarSand Tango
- zoomiej
- Vessel Info: 2001 Carver 466 MY
- Been thanked: 3 times
Thanks Dan, and great idea.
Found it. It is a bag inside the vacuum vs. A canister. Thanks.....J.
