ETA Circuit Breakert
tonyiiiafl
Has thanked: 601 times
Been thanked: 190 times
Postby tonyiiiafl » July 7th, 2019, 3:14 pm
I was running some wires through the area of the Battery disconnect switch, and when I was replacing the panel, a pole broke off of one of the ETA 50A circuit breakers. I know I am a bit needy lately, but does anyone have a source for these? I saw some on EBAY but not exact match ups. It was an ACC breaker, and 50 AMPS. Attached is a photo of the numbers on the side. It appears to be sistered up to the 60A breaker next to it. Thanks again, the wealth of knowledge here is outstanding!
tonyiiiafl
Re: ETA Circuit Breakert
Postby tonyiiiafl » July 8th, 2019, 10:39 am
Found a source. Custom Marine in SC. However they do lot the 50A anymore only a 60 which is what is sisters up to it. I had to go with the 60. However I am OK with that as if it trips it would be for. Catastrophic failure and the cable is the same size to and from the 50 as the 60
