Marine Air Systems 'HHH' error code
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
Thanks in advance!
- rcoff512
- Vessel Info: 1999 Carver Voyager 450
Home Port, Long Island NY USA - Has thanked: 12 times
- Been thanked: 8 times
- Contact:
Re: Marine Air Systems 'HHH' error code
Rich
Thanks! Any suggestions on how to do this? I have three other units in the boat that are operating well.
- Been thanked: 615 times
- buster53
- Been thanked: 261 times
Have you checked your filter and behind the filter, what do the fins look like on your compressor?
buster53 wrote:Source of the post Ok, I assume you have one water pump for all your units. The problem unit...what is the water flow like for that unit? Has it diminhed any from the usual flow?
Yes, air filter and compressor fins are clean. Water flow appears to usual so sounds like I may need a Freon recharge
- Has thanked: 324 times
- Been thanked: 595 times
- Has thanked: 455 times
- Been thanked: 1671 times
Users browsing this forum: No registered users and 228 guests
