396 Aft Cabin with weird problem with shore power
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 23 times
Any thoughts before I pay my electrician to look at the issue?
- Has thanked: 580 times
- Been thanked: 1210 times
Re: 396 Aft Cabin with weird problem with shore power
Put some dielectric grease on the cords ends and make sure they are connected properly at the pedestal and the boat....push and turn and attach your locking rings......if there is play after all that then there is a problem with the pedestal socket or your plug ends.
Please remember to unplug both ends ( power totally off ) before doing any inspection.
- Has thanked: 324 times
- Been thanked: 595 times
Dont be afraid to use a little fine grit sandpaper or scotch brite pad.
If you still have a problem pull out the shore power receptacles on the boat and check the connection on the back.
Bad shore power connection = high amp draw=failed equipment.
- buster53
- Been thanked: 262 times
Users browsing this forum: No registered users and 58 guests
