Rotella T4 15w 40
Rotella T4 15w 40
Post by Midnightsun »
Did my oil changes and all the filters on both engines and generator today. I always used Rotella T4 in my previous gas engines, the SeaDoo and even my summer ragtop. Needless to say I use a lot as the boat alone requires about 12 gallons. They have 5g pails of T4 at Walmart for $57 and some change CDN. Probably the cheapest I have ever seen it as of late. Bought 3 more pails for next years oil change. :-D Not sure if this is provincial or Canada wide.
Oddly enough everything in the states when it comes to gas and oil is always cheaper, exception Rotella. That comes to $43 US for 5G.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Re: Rotella T4 15w 40
Post by pepmyster »
Thanks for the heads up! Did my oil changes already, and, only use Rotella also.
Post by mjk1040 »
Found out Tractor Supply Brand is Rotella, same oil different label. Do u have a Tractor Supply in Canada?
As for availability it seems to be all of Canada. https://www.walmart.ca/search/rotella%20pail
mjk1040 wrote:QR_BBPOST Found out Tractor Supply Brand is Rotella, same oil different label. Do u have a Tractor Supply in Canada?
I do not believe we have those here.
Post by g36 »
didnt know about tractors supply being rotella howd you find that out?
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Post by vineyardgray »
Isn't TSC the same as Tractor Supply?
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
darrenlife
Been thanked: 36 times
Post by darrenlife »
I don’t mean to open a can of worm but I thought I read somewhere that Shell changed their Rotella formula to contain less zinc and may not be as useful in gas engines?
I always used Rotella on my previous diesel boat but am paying out the nose for the Merc 25W40 semi-synthetic, would love to go back to Rotella
Post by tomschauer »
Darren, I have always run Mobil 1 15/50 full synthetic in my merc gassers. Cheaper than the merc semi, and better oil.
darrenlife wrote:QR_BBPOST I don’t mean to open a can of worm but?.....
I'll open up another can of worms; in all my OEM training, we've always been taught that Dino oil has a shelf life of a year in an unopened container and that you shouldn't use oil from a container that's been opened for more than 6 months. I prefer not to use anything that's been opened for more than 3 months. Now maybe it's marketing but it is true that Dino oil and additives start to slowly degrade over time. With this in mind, consider that when you buy oil, it may have been on the shelf for who knows how long, then you're keeping it for a year until your next oil change, then you're expecting it to be in you engine for a year and expect it to perform to spec. For this reason, I only buy oils when I plan to use them right away.
