1800 RPM Kohler vs 3600 RPM Westerbeke
- vineyardgray
- Captain
- Has thanked: 125 times
- Been thanked: 32 times
- Contact:
I have been eyeing used westerbeke units and most I can find are only 5kw, which is probably fine but also are 3600rpm.
How much louder will a 3600 be vs an 1800? Will the "exhaust tone" be that much more annoying vs the low rumble of an 1800 RPM unit?
1988 Carver
3867 Santego
PCYC
- ColRon
- Has thanked: 77 times
- Been thanked: 154 times
Re: 1800 RPM Kohler vs 3600 RPM Westerbeke
My previous boat, Moody Blue, had an Onan 4KW single cylinder genset that ran at 3600rpm. There isn't anyway on God's green earth I would ever want one of those screaming meanies again. While the exhaust noise was louder, it was the sound of the engine, not the exhaust that really made the difference. It was SIGNIFICANTLY louder than my 1800rpm 4 cylinder Kohler. You couldn't sit in the cockpit and have a normal conversation it was so loud.
“Escape Plan”
Murray, KY
- Has thanked: 585 times
- Been thanked: 1231 times
Now we have this 3600 rpm revmaster 7200 ( thats what I call it )....its in an insulated box, fairly quiet exhaust but it has a sound to it that I don't like, it starts up instant on kill....this makes it eat water pumps, is hard on parts as there is no warm up. Basically a 2 cylinder lawn tractor engine with only a 2 pole gen head.
My opinion is , if it was my choice, I would only buy the 1800 rpm model, I just believe them to be made a lot better. Get one you can maintain easily when in position in the boat, this means changing the water pump impellor/ oil changes.
What cost differences are you seeing here ??
- Cooler
- Has thanked: 68 times
- Been thanked: 400 times
- Has thanked: 324 times
- Been thanked: 595 times
- Keith S
- Vessel Info: 2005 38 Super Sport
- Been thanked: 21 times
- ColRon
“Escape Plan”
Murray, KY
- vineyardgray
- Captain
- Contact:
I kinda hate being being tied to technology that is no longer supported and with scarce or NLA parts.
1988 Carver
3867 Santego
PCYC
- Has thanked: 72 times
- Been thanked: 1055 times
THAT is what usually kills them.
vineyardgray wrote:Source of the postThe mechanic said it wouldn't start to winterize so I started looking at parts - which are scarce - and then replacement units.
So did it get winterized or not? That could be bad if you don't get any trapped water out of there. If I couldn't get it to start, I'd pull off a few hoses and pump some -100 AF in there so you don't ruin the block, because that WOULD spell the end for the unit!
