Leave charger on or not?
bobcinga
Vessel Info: 2006 CMY 41
Been thanked: 4 times
Postby bobcinga » December 16th, 2019, 7:01 pm
Our 41 CMY has a CCharles 60amp Model 5000 three bank charger. I just replaced all three batteries with Maintenance free lead acid batteries. My question is should I leave the charger on all the time or turn it off when we are not there? Probably no longer than three weeks between boat visits and while it can get cold, bildge shouldn’t drop below 50 degrees.
Oh one more thing. No idea what setting the charger is set to related to lead acid, gel, or AGM. Not sure what CCharles or Carver was thinking, but the switch to change the setting is on the back of the charger and it is mounted to the back port bulkhead with about 3 inches between muffler and unit. No way to get to it that I can see.
Been thanked: 243 times
Re: Leave charger on or not?
Postby mjk1040 » December 16th, 2019, 7:31 pm
I'd turn it off. A little spoiled food is cheaper than a fire onboard should something go wrong while your gone..
Has thanked: 585 times
Been thanked: 1238 times
Postby bud37 » December 16th, 2019, 7:53 pm
The question might be .....does the charger get to float..13.2 to maybe 13.6 volts. This will depend on the charger battery setting if it has one.
If so then I see no reason to worry about it, they are designed for this....but myself, I personally shut everything off when we leave the boat. I wouldn't worry about cold batteries in the bilge , fully charged we leave them all winter at - temps with no charger on them and they are fine.
Been thanked: 625 times
Postby g36 » December 16th, 2019, 8:57 pm
I leave my charger on year round. Have the same start batteries and my trojan house batteries for 6 yrs now. I don't know if you shut your seacocks while gone but if you don't and you have a leak of any size your bilge pumps will drain your batteries quickly I figure if the charger is on it can by some more time
Has thanked: 459 times
Been thanked: 1706 times
Postby Viper » December 16th, 2019, 10:45 pm
I would leave the charger on as it is a smart charger that will switch to a float mode after the bank is charged. This will maintain the charge while minimizing electrolyte loss. Having said that, it doesn't mean that the fluid levels in the batteries never need checking, they still do. As g36 mentioned, springing a leak is a perfect example of why you'd want the charger on at all times if you're in the water.
I believe the 5000 series comes set from factory to the GEL charge curve. This may have been changed at Carver though prior to the install. The GEL curve however while set to a charge voltage just slightly below the lead acid curve, both the GEL and lead acid setting have the same float voltage.
Been thanked: 400 times
Postby Cooler » December 17th, 2019, 12:13 pm
Bobcinga - if you have a small mirror to stick behind the charger, you will see the setting. Available at automotive stores for cheap. I keep one on board because there is always a use for it. It is standard equipment in mechanics tool box. If you are in the water, there is probably no real need to shut down. If you are stored in/at a facility on the hard, check with the facility regarding rules of storage. Most storage contractors will require you turn everything off and do not leave power cord plugged in if you are not there. My facility requires no connection, with the caveat that if a power cord is plugged in, it will immediately be unplugged by the owner. That is agreed to on storage contract. I do plug in when I am there, which is at least every couple of weeks. The last boat fire at a marina in our area was caused by a charger. Took out 4 boats, and the owner of the primary said his charger was a smart charger less than a year old. 8-) er
Has thanked: 270 times
Been thanked: 1162 times
Postby Midnightsun » December 18th, 2019, 5:48 am
Only time the charger is not connected is during winter layup since no power available. My toys such as seadoo, snowmobile and classic car all are plugged in during the off season. ;-) FYI, NOCO recently came out with a very compact maintenance charger using the latest tech. These are great for mounting in various toys. https://no.co/genius2d
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Postby Tireless » December 18th, 2019, 12:51 pm
I leave my battery chargers on all the time and monitor fluid levels regularly when the boat is in the water. In the winter I top them up with a charge and disconnect the neutrals. I have never had an issue and get a good battery life.
While in the water, I like them on charge for reasons discussed. This was also recommended to me by the Carver dealer when I bought my first boat. In the winter I also top up the charge and disconnect the neutrals an my Jet Boat and dinghy and have yet to have an issue. I have my Camaro on a battery maintainer all winter in the garage, due to the electrical systems on board.
With the temps up here in the winter, failure to top the batteries to a full charge, you run the risk of them freezing.
Postby bud37 » December 18th, 2019, 1:20 pm
bobcinga wrote:Source of the post Oh one more thing. No idea what setting the charger is set to related to lead acid, gel, or AGM. Not sure what CCharles or Carver was thinking, but the switch to change the setting is on the back of the charger and it is mounted to the back port bulkhead with about 3 inches between muffler and unit. No way to get to it that I can see.
If you have the one with the analog gauge on the front, I am not so sure there is a switch back there, I just changed ours out ( 2001 model ) and there was no switch, It may have come set from the factory for particular charge profiles. Regardless you should still check your batteries with a volt meter after the charger has been on for a number of hours to see what voltage is being applied. If it is over 14 volts after say 24 hours charge, then the charger or something is off . I would be hesitant to leave a charger running at over 14 volts for long periods with no draw on it.....
I changed our because it would not get to float of 13,2 to 13.6 about....was always 14.2 at the lowest which I believe is the bulk charge number.
Users browsing this forum: No registered users and 93 guests
