carver 3207 fuel sending unit
- ataylor233
- Has thanked: 83 times
- Been thanked: 7 times
i know there are soooooooo many options here does anyone know of a more direct replacement for the stock medallion instruments b-1321... if not How deep is the Tank so i can find one that will work better?
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Re: carver 3207 fuel sending unit
Moehler makes one that is adjustable for tanks from 4" to 28": Moeller Marine Products, Fuel Tank Sending Units, 4 to 28 Inch Tanks
https://www.amazon.com/Moeller-Marine-E ... 55&sr=8-14
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Lake Norman, NC
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
I haven't trusted my fuel gauge in either tank sense I owned my 3607. The most accurate and cheapest gauge that I have found is a 1/4" x 3' wood dowel rod that you can get at any hardware store for $2. I simply run it down into the tank via a access hole found on the top of the tank and then visually see the level. Basically just like the oil dip-stick on the engine. Just have to be sure to put the plug back into the access hole.
