Trim Rings for Saloon Lights for 2004 Carver 466
wkeith
Vessel Info: 2004 Carver 466 Aft Cabin MY
Has thanked: 8 times
Been thanked: 14 times
Post by wkeith »
I'm sure this has been covered many times before. Where can you purchase the replacement lights and gold and silver trim rings found in most models. Recently replaced all lights to LED's and what a great improvement. Had trouble with some of the trim rings going back on and a couple broke.
Thanks for the help. This is such a great resource.
Walter
Re: Trim Rings for Saloon Lights for 2004 Carver 466
Post by g36 »
You'll find lots of discussions on here about this. The search feature should bring them up search for.... trim rings.The oem rings are all but exhausted from all sources that used to carry them. My suggestion if you have converted all your oems to led and you have a couple trim rings cracked would be to try and consolidate the bad ones by moving all good rings to the areas you can and then actually replace the bad ones with new fixtures. That way you have all the same in main areas and will only purchase a few new fixtures to be the same in other spots. The search will also show options of what others had installed.
Post by g36 »
Its a good chance he has the hera 1 lights which were the standard i believe at least in 97 and 98. And if so is what are all gone but you never know.if he does find stock i hope he will post for everyone else.
wkeith
Post by wkeith »
Thank you all, very informative!!!
Post by Midnightsun »
Never mind the lights, I want to know how the heck you got the option of a saloon in your boat. :-D
wkeith
Post by wkeith »
Too funny!
Didn't catch that when proof reading. Maybe I could offer a retrofit kit for saloon upgrade for most models!!!
Thanks,
Walter
