One of my bridge lights is not working.
BarryK
Vessel Info: 1990 Santego 3467
Twin 454 Crusaders
Has thanked: 12 times
Been thanked: 6 times
Post by BarryK »
I have several of these lights on the bridge. One is not working. How do I open it and where can I get a replacement bulb? I don't want to break it.
Thanks,
Barry
Re: One of my bridge lights is not working.
Post by g36 »
If you see no screw etc on the outside trim then it most likely pops on. Carefully take a small screwdriver etc and gently pry around the outside next to the wall its mounted in and the trim ring should pop off. Then you can see what bulb it has. Another option Is there a light near a opening or storage compartment you could look behind for how it might be mounted?
BarryK
Twin 454 Crusaders
Post by BarryK »
Thank you! I should be able to get behind it and see how it is mounted.
Helmsman
Has thanked: 73 times
Been thanked: 42 times
Post by Helmsman »
BarryK wrote:QR_BBPOST Thank you! I should be able to get behind it and see how it is mounted.
Can you let us know what you find?
Been thanked: 285 times
Post by buster53 »
When you do open it up, find a replacement LED bulb and replace all of them. Chances are you will never have to replace them in the future as they last thousands of hours
BarryK
Twin 454 Crusaders
Post by BarryK »
It is a sealed 3 LED light. They are available from multiple sellers on Amazon, called a courtesy light. 3" x 1 1/4". Inexpensive, waterproof.
https://www.amazon.com/Partsam-Courtesy ... 99&sr=8-14
I would need to replace the whole unit; the LEDs are not replacable.
I wiggled the wires going into the light and it is working again for now. It is a problem with the fixture itself, not the crimp connections.
Take care,
Barry
