Marine Air Max or ECU control
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Post by tonyiiiafl »
My 1994 Carver 390CPMY has a Marine Air unit for the forward and also a digital panel, which I believe is the ECU (Now called they FX-Maxx) control. The inside temp is way off, by about 8 degrees. I have scoured the web for programming or an owners manual, but so far nothing. Does anyone have any documentation on this control?
Re: Marine Air Max or ECU control
Post by g36 »
Fxmaxx is made by micro aire. Is this the one you have? If so the owners manual pdf is about 3/4 down the page....https://citimarinestore.com/en/micro-ai ... -black_x01
tonyiiiafl
BINGO! Thank you very much!
Post by g36 »
You bet
