battery and windlass
tgebler
Vessel Info: 2000 396 AC
Has thanked: 5 times
Been thanked: 23 times
Postby tgebler » August 24th, 2020, 10:31 am
I have a 2000 396 Aft Cabin. The windlass is running very slowly and to get it to work I have to turn off all other electrical devices. Could I need a new battery and, if so, which battery is sending power to the Maxwell Freedom 800 windlass? Help!!
Thanks.
Has thanked: 585 times
Been thanked: 1231 times
Re: battery and windlass
Postby bud37 » August 24th, 2020, 11:01 am
Not sure of wiring, maybe the house battery....but the question, do you have the engines running when you operate the windlass ?
If you check the batteries separately with a voltmeter as the windlass is operated ( you will see a volt drop ) you should find the battery it is wired to in my opinion. Also check all your battery connections for corrosion and loose connectors etc.
tgebler
Postby tgebler » August 24th, 2020, 11:31 am
Thanks. There are six batteries so I will need to check each one. And I do have the engines running when operating the windlass.
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » August 24th, 2020, 12:07 pm
Also check the power cable connections at the windless motor.
May want to check there first.
tgebler
Postby tgebler » September 7th, 2020, 10:01 am
So..... I checked the batteries, all better than 12v and checked all the connections and no problems there. Is it possible I need a new windlass motor? Any other suggestions would be appreciated. Thanks.
Postby bud37 » September 7th, 2020, 10:14 am
tgebler wrote:Source of the post So..... I checked the batteries, all better than 12v and checked all the connections and no problems there. Is it possible I need a new windlass motor? Any other suggestions would be appreciated. Thanks.
When you say better than 12volts....how much....because a fully charged battery should be around 12.7 volts after the surface charge is gone.
tgebler
Postby tgebler » September 9th, 2020, 7:18 pm
My multimeter shows over 13 volts. any thoughts?
tgebler
Postby tgebler » September 9th, 2020, 7:37 pm
Will is the best!!! I just him an email and he called me with in 15 minutes. He gave me several things to check and explained electrical service to a novice. If anyone has a windlass issue, reach out to him first. Thanks for the referral.
tgebler
Postby tgebler » September 9th, 2020, 7:38 pm
that is Will at Vetus/Maxwell. wvrooman@vetus.com
