Port engine won't start unless generator is running
- Vessel Info: 2003 366
Ideas?
- Has thanked: 456 times
- Been thanked: 1671 times
Re: Port engine won't start unless generator is running
Sounds like you have a bad battery/s or a bad connection. Most likely starts on shore power and with the generator running because your charger is on and providing just enough power to start the engine. Chances are you have two battery banks; one for starting an engine, and the other for starting the other engine and house loads. One of those banks isn't doing its job. I would disconnect all the batteries and do a proper test on each one, including checking fluids.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Greg
- buster53
- Been thanked: 262 times
If not on shore power or genset, does the port engine do anything, like turn over very slowly, too slow to start. Do you just get a click?
Will the port engine do anything if the starboard engine is already running?
Do you have a 1-2-Both-Off battery switch? Where is it set? Have you played around with it...1, 2 or both. Any change between settings?
- mjk1040
- Been thanked: 242 times
Users browsing this forum: No registered users and 59 guests
