Kahlenberg Zero Series Horn Install
Has thanked: 270 times
Been thanked: 1160 times
Postby Midnightsun » September 1st, 2020, 6:53 am
So my electric el cheapo horns died, they never did sound very loud to begin with. Went to buy new ones and then did something crazy. :beergood: Instead of buying cheap poor sounding run of the mill electric horns for a couple hundred, I went with the creme de la creme which is Kahlenberg. https://www.kahlenberg.com/products/mar ... horns.html
This involves installing a mini compressor with tank, air hose, a switch and an air valve. Not complicated at all but my estimate is about $1600 when all is said and done. I tested the horns on the bench, holy $hit is all I can say. Nobody can miss me when I toot guaranteed. :-D
I added this switch to the dash so the compressor can be turned on or off.
This will give you an idea of overall size, tank is about 18" long
Last edited by Midnightsun on September 1st, 2020, 8:59 am, edited 3 times in total.
Been thanked: 621 times
Re: Kahlenberg Zero Series Horn Install
Postby g36 » September 1st, 2020, 8:30 am
Yea baby!
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Postby AaHubb » September 1st, 2020, 10:12 am
Interesting, mine just has a compressor, no tank. They work fine though, nice and LOUD!
..Aaron
ps: Wow the price has gone up a lot! :-O
'99 404 CPMY
SeaDragon
Postby Midnightsun » September 1st, 2020, 10:42 am
Believe me I have had the no tank style compressor air horns on another boat, no comparison whatsoever. Tankless air horns are not that expensive. https://www.globalindustrial.ca/p/vehic ... gJDY_D_BwE
Brazil
Hugo
Been thanked: 23 times
Postby Hugo » September 1st, 2020, 3:30 pm
I have the same setup, you'll be happy with them. Mine are chrome, it's a bit of upkeep but they look awesome shined up.
Put another actuated valve under the tank drain (like you''re using to open air to horns) and install a switch somewhere so you can bleed water/drain the tank without having to get to the drain plug if you're putting it somewhere it's hard to access. I put mine in the bridge with the rest of electronics and it's hard to get in so that's worked great. I ran a piece of hose off the valve to a place where the water will drain nicely if any in there.
You'll find at 150psi they're very loud, a bit much. I run mine at 100 psi and think they sound better and a few less decibels.
Postby Midnightsun » September 1st, 2020, 3:58 pm
Great idea, never thought of that. Thanks, you get a sticky star. :-D
I got a tall and skinny friend lined up as I am also installing it in the bridge.
Brazil
Hugo
Postby Hugo » September 1st, 2020, 5:13 pm
The installation will go better if your tall and skinny friend is of the opposite sex.
pepmyster
8.1 Volvo Penta
Fresh water boating
Been thanked: 201 times
Postby pepmyster » September 2nd, 2020, 6:00 am
What a setup!!!!! Can't wait to hear them!!!!!!!!!!!!!!!!!
Postby Midnightsun » September 2nd, 2020, 6:05 am
When I toot at Prescott you will hear me at Pecks. :-D
Has thanked: 457 times
Been thanked: 1697 times
Postby Viper » September 2nd, 2020, 6:36 am
Looking good Hans :down:
