Kohler 7.3 Question
- denpooch
- Has thanked: 85 times
- Been thanked: 86 times
Kohler 7.3 Question
I start the engine, it turns over, runs for 5 seconds and stalls. Last week I replaced the fuel filter. There is plenty of oil and the impeller is new.
All thoughts and leads are appreciated.
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
Re: Kohler 7.3 Question
Make sure your power is off also when you start it. Get it running, then introduce the load.
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
1. Fuel? How much fuel is in the tank? Remember most boats have the genny pickup above the main pickup so you can't run a tank dry on the genset. If you are 1/4 tank or less, you are sucking air.
2. Oil and coolant level or sensor? Auto shutoff for low oil and low coolant - if both are OK, check the sensors - sometimes the terminals break or a wire comes loose.
3. Fuel filter - how old is it? Have you had any issues with water in fuel?
4. Fuel pump? The electric fuel pumps are pretty reliable, but check connections and output pressure.
Hope this helps - good luck!
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- KeithS
- Vessel Info: 2005 38SS
- Been thanked: 23 times
The 5/7.3E series had a bit of a quirky thing with the spark plugs. Due to the design of the Kawasaki intake manifold, the rear plug runs cooler than the front plug. It runs cool enough that at light loads it will foul the plug. An occasional run with a heavy load will help. This does not usually affect starting though. In fact sometimes the generator will run just fine until the load is more than the one cylinder that is firing can handle. Then is will misfire and run like crap.
- denpooch
Full tank fuel. Fuel filter 1 week old. Old filter was changed and it ran well for a while. I thought problem solved. (the old filter was faulty and allowing air to enter the system)
The fluids are topped off but I will check the sensor wires. (I assume I can locate these from the Kohler 7.3 schematic diagram)
When starting, I release and it runs a few seconds and then stalls. I have a Dockmate who has an issue where it will run until he releases the switch and then dies.
One guy said it may not be putting out enough voltage and it can be a voltage regulator issue.
I appreciate your help.
- buster53
- Been thanked: 262 times
- KeithS
- denpooch
- denpooch
She was running GREAT, until....
It was running fine the other day and then started 'searching' (ie.rpm's increasing-decreasing, etc). Eventually it stalled.
Now I start it, it searches for a few minute and stalls.
Question, is there an adjustment on the carburetor to overcome that issue or is it best to replace the carb which is only about 2 years old.
If an adjustment, can you let me know where I can find the adjustment screw?
Thanks.
- Gary Rose
- Vessel Info: 2000 356 carver aft
- Has thanked: 5 times
- Been thanked: 3 times
Users browsing this forum: No registered users and 144 guests
