Charging query
tonyiiiafl
Has thanked: 601 times
Been thanked: 190 times
Charging query
Postby tonyiiiafl » September 5th, 2020, 9:12 am
On my 1994 390CPMY 454’s, When underway, if I run the house battery, the house battery charges by showing 14.0 +/- volts on The starboard engine gauge at the helm. The port shows 12.7. Now if I switch over, the port shows 14.0=/- and the starboard shows 12.7. When I leave it on both to cruise then BOTH gauges show 14.0 =/- volts. Upon reaching my destination, both batteries are fully charged. is this normal or should both charge. I checked the selector switch unit her stairs and all appears not to have been mucked with. SO, what I have done is run with switch on both, and then switch to the house when I shut down engines. ??
Has thanked: 585 times
Been thanked: 1231 times
Re: Charging query
Postby bud37 » September 5th, 2020, 10:45 am
Yup that is exactly how they are wired....normal for that system ....you start the engines with the start batteries then switch to both while running, then back to house with engines off. I would also have it in the start position for when using the windlass. That is exactly how I used our system ....requires some manual switching but at least it keeps you aware of the state of your batteries.
tonyiiiafl
Re: Charging query
Postby tonyiiiafl » September 5th, 2020, 11:06 am
GREAT news, as I was a wondering if that was going to be my next project....unf%$k another previous owner shoddy stuff.
Has thanked: 458 times
Been thanked: 1699 times
Re: Charging query
Postby Viper » September 5th, 2020, 11:19 pm
Ya unfortunately that's a consequence of how the DC system is wired using a selector switch, that's one of the reasons why I don't like that setup. It can be changed though with a little work.
Been thanked: 1055 times
Re: Charging query
Postby km1125 » September 7th, 2020, 7:27 pm
You can add a "voltage sensing relay" between the batteries, so when one is being charged it will connect to the other one and apply a charge to that one too. When there is no longer a charge available (from any source) it will disconnect between the batteries so you don't run them both down if you continue to have a load on.
Been thanked: 622 times
Re: Charging query
Postby g36 » September 8th, 2020, 12:35 pm
Those charging relays are very handy
