Mercruiser 454 Carb engines
tonyiiiafl
Has thanked: 601 times
Been thanked: 190 times
Postby tonyiiiafl » September 27th, 2020, 8:19 pm
On my 1994 390 I have the port engine which is original at 1180 hours, Starboard 3 years old at 125 hours. I have been using Quicksilver 25W40 oil and same filters, Quicksilver. What is the opinion of switching to the 25W40 synthetic blend? I don’t run hard if that matters, but those girls are pushing a lot of boat.
Has thanked: 456 times
Been thanked: 1671 times
Re: Mercruiser 454 Carb engines
Postby Viper » September 28th, 2020, 6:52 am
Really comes down to how much you run the engines IMO. If you only require one oil change annually, then I say mineral oil is fine unless the engine specifically requires otherwise. The synthetics remain more stable longer, so if you boat year round and wanted to stretch out that oil change interval, then go synthetic. Since we're in northern climes, and the recommendation is to change the oil prior to every winter layup even if there was little use, then mineral oil will do IMO.
tonyiiiafl
Postby tonyiiiafl » September 28th, 2020, 7:14 am
Thank you. That confirmed my opinion also.
Users browsing this forum: No registered users and 93 guests
