Mounting brackets on transom
mikesparker
Vessel Info: 1985 3227 w/Crusader 220s
Has thanked: 28 times
Been thanked: 3 times
Post by mikesparker »
Hello again! 1985 3227. How do you gain access to the inside of the transom to install brackets? The only way I can see is via the fuel fillers...help!
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Re: Mounting brackets on transom
Post by SplashyLady »
You can reach up from inside under the deck, and there is a pie plate on the upper starboard side if you have the swim platform shower attachment. Otherwise, you will need to cut a hole and put a pie plate hatch in if you can't reach up high enough from inside. Depending on what you are installing, you could also use screw anchors or toggles and only work from one side.
Good luck!
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
