Carver 404 / 396 ease of maintenance
- MSC
- Vessel Info: Shopping for a Carver 405 or 406
I've started shopping around for a Carver 396 or 404 about 20 years old with diesel power. I really like the 404 because of the rear cabin door onto the cockpit. Good for rear cabin ventilation while not using AC. I will mainly be cruising in Florida and the Bahamas.
However, I would like to do routine engine maintenance myself and an wondering if the engine room of the 404 is really too right, especially with diesels. How difficult is it to get at both raw water pumps, for example, or both heat exchangers?
Does the 396 have a much better engine room? Should I rule out the 404 because of difficulty of maintenance which is an important factor in a boat of that age?
I like the 444 for the same reasons as the 404, but it is getting longer, and heavier, and more risk of being underpowered and, of course, more expensive by the foor for everything.
My needs are comfortable cruising during the winter for two people with occasional visits from another couple for a week to 10 days.
Looking forward to hearing about your expériences,
Mark C
- buster53
- Been thanked: 261 times
Re: Carver 404 / 396 ease of maintenance
Never been in the engine room of a 396 but it has to have more engine room than a 356. I used to have a 3807 and engine access was much better than my 356.
- Has thanked: 579 times
- Been thanked: 1210 times
- Has thanked: 455 times
- Been thanked: 1671 times
The best thing to do is assess the access to all the areas in each model that you'll need to get to for servicing maintenance items, winterizing if applicable, etc. While you're at it, look for items that are difficult to get to and would require major dismantling to get to them. When you're ready to make a decision, compare your notes for each model. If you tackle this type of work yourself, it's your time, if you hire someone to do it, access will be a huge determining factor in the cost of the job.
Good luck in your search and keep us posted.
- MSC
I have been starting to realize, as bud37 says, that I would probably have to buy more boat than I need to keep the maintenance doable. I would like to do as much as possible myself without becoming a contorsionist.
Viper's advice about taking notes on the systems of each model is good too. I will check out a 404/356 and a 396/444 and see which engine room I think I will be better able to slither around.
Thank you all for your comments. If anyone has anything to add, feel free.
Thanks a lot.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
I like the 44 and the 404, however, I like the size of the 44 and the fact that it has diesels. It moves along pretty good for a big heavy boat, but the room you have makes it well worth it.
The diesels are much more efficient than the gas, from my experience.
Good luck.
Greg
- MSC
I am definitely going with diesels. I currently have a 6000 lb boat with a 7.5L Mercruiser and I cannot imagine powering a 30 000 lb boat with two of those.
Does your 44 have 2 x 370 diesels? Are they Cummins or Volvo? I have seen some 396 and 444 with 330 hp diesels. Do you think they are underpowered? Will the diesel have to be flat out to get it up on a plane?
Thanking you in advance,
Mark
- Tireless
MSC wrote:Source of the post Does your 44 have 2 x 370 diesels? Are they Cummins or Volvo? I have seen some 396 and 444 with 330 hp diesels. Do you think they are underpowered? Will the diesel have to be flat out to get it up on a plane?
I have twin Volvo Penta D6 370 Hp. diesels. At 90%, 3240 rpm's it planes out at 20-21 mph. WOT for the D6 is 3600 rpm. If you load her up with fuel and a dinghy on the back, I may loose .5 - 1 mph. I suspect the 330 hp. would be under powered in a 44 CMY. I wish mine were a bit bigger in my boat as well, however, 20-21 mph is pretty respectable for a 36,000 lb. boat.
Greg
- Has thanked: 324 times
- Been thanked: 595 times
I guess you need to look at what is regular maintenance and can it be done without to much trouble.
For my 355 (same access as 356), oil and fuel filter changes are not bad at all. plugs on the out board sides of both engines are not ideal, but not bad, but with the newer plugs, that's once every several years at most. My port raw water pump is no problem but the starboard requires me to remove the heat exchanger so I can get into the "hole" to replace the pump or impeller. This adds 2 hours to a 2 hour job.
To replace the outboard manifolds on either engine would be good days work for one person.
Yanking either engine is something i hope to never do. If I ever have to yank a trans, I would hope its the starboard.
If you're in a winterizing area of Canada, check how easy it is to get to the mufflers for draining them. Some are impossible to access without a major dismantle, so it results in needing more antifreeze to displace all the water in them. I've had to re & re a few mufflers for people that couldn't drain and didn't run enough antifreeze through them. No access is also a marina's way out of taking responsibility for frost damage to something you hired them to winterize.
Users browsing this forum: No registered users and 83 guests
