Alternator replacement
- jsurfwhite
- Vessel Info: 2000 Carver 356 Aft Deck
- Has thanked: 12 times
- Been thanked: 4 times
I have a 7.4 L gas mercruiser on a 2000 Carver 356 Aft Deck. The alternator is frozen, locked up, and needs to be replaced. Do I go after-market or OEM? Thanks
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 8 times
- Been thanked: 23 times
Re: Alternator replacement
Aftermarket would be fine, provided it is some quality item. I've heard mixed reviews in the Sierra, but wouldn't be that concerned if I had to make the purchase. Especially if you have twin engines, where you can tolerate a failure pretty easily.
That said, my first choice would be a local alternator/starter shop. If it's any good, they know what needs to be done and likely have everything in stock. They also would well know the marine standards. We have a shop locally that I've dealt with for over 40 years, so I'd go with them in a heartbeat. You likely have a similar shop somewhere near you too.
- waybomb
- CYO Moderator
- Been thanked: 492 times
Check out DB Electric.
- jsurfwhite
Update on alternator. OEM part was Mando AC165617. Bought alternator from DB Electric, and installed. Everything fit, and up and running.
