22x22 Left and Right Propellers, Shafts, Struts, Everything - 1 3/8th shafts
Forum rules
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
- Tbenson1
Long story short, I acquired these with the intention of shortening and milling down one of the shafts to work on my Searay. Little did I know the extreme cost vs simply buying new.
I just called Carver to see what they could cross reference part numbers to figure out what these were made for. Awaiting a callback.
Things I know:
1. 4 Blade, 22 inch, 22 pitch props, matching left and right. Props have minor dings but they are shown in photos.
2. 1 3/8th shafts, this was confirmed by the strut assembly from Carver.
3. Both shafts appear to be approx 103", however, the tape was slightly curved during measurement.
4. These are complete front to back, from the end nut where the propeller mounts to the end flange to bolt to transmission.
Completely identical other than being left and right-hand props.
Selling as a complete set. At this time, I have no idea what they go to. The only marking on the strut is "Carver 51136". Carver said they would call or email back once they cross-referenced some stuff for me and narrow it down.
If you are a Great Looper, this could ensure you have zero prop or shaft issues, as it's a complete set.
Ebay sells a matching set of props for approx 16-1800 for all nice and shiny ones. No idea what the shafts are worth and the rest. Thinking a number that starts with a 3 if I had to guess.
No, I can't ship. It takes 2 full-grown men to pick these up. They are heavy as crap. Bring a truck, I'll help ya load. What you see is what you get. I make zero claim these are perfect shape but I have a feeling these aren't easy to come by.
*I know I am a new member, you can see my eBay store, my business, however, you want to verify, just lemme know!*
Hopefully the forum will give me a notification of a PM about these or a comment.
Things I know:
Re: 22x22 Left and Right Propellers, Shafts, Struts, Everything - 1 3/8th shafts
The prop size and shaft diameter were used on the 3607s. Not sure of the length, although I did have to have one replaced before, so I really should know that.
It would also be great if you knew the shafts were not bent. Is the coupling for the transmission end on the shaft? I'm not personally in need, but others might be interested in that info.
- Tbenson1
km1125 wrote:Qr Bbpost The prop size and shaft diameter were used on the 3607s. Not sure of the length, although I did have to have one replaced before, so I really should know that.
Carver just emailed back. This is all the parts listed he saw.
Travis;
These parts are for a earlier Carver 3307 aft cabin. This could be the 350 or 355 up to 1998. I will list all the parts in the pictures.
PART- 5113600 STRUT:1.38"D 12.25DG AFT
-------------------VENDOR----------------------------------
PART NO./ NAME / PHONE
STRUT CROIX GEAR & MACHINING 800-544-1487
PART- 5122600 SHFT:1-3/8 X 101 DBL TPR
SHFT:1-3/8 X 101 DBL CROIX GEAR & MACHINING 800-544-1487
PART- 5106100 ZINC:1-3/8" ELECTRL COLLA
X-6 CAMP COMPANY 727-391-4976
PART- 5209800 PROP:22X22 DQ RH 1-3/8
351034 MICHIGAN WHEEL MARINE 800-369-4335
PART- 5209900 PROP:22X22 DQ LH 1-3/8
351035 MICHIGAN WHEEL MARINE 800-369-4335
PART- 5113700 STRUT:1.38"D 12.25DG INT
Pat Johnson
Parts Coordinator
From everything I can tell, the shafts are straight and true. I would need to complete disassemble them to confirm but eyeballing, they look fine.
- waybomb
- CYO Moderator
- Been thanked: 492 times
It would help if you listed exactly how much you wanted for the pair, and if you would be willing to drop them off at a local shipper to have them pack and ship.
- Tbenson1
Truth be told, I don't know what they are worth. I'm guessing 3500 if that's fair. And I can assist transporting to a shipper if needed, but you do not want to attempt to take these things to UPS and get that bill lol
- yachtracerbf
- Vessel Info: 1994 Carver 350 Aft Cabin
Are these still available?
- Njlarry
- Has thanked: 8 times
Are the propss still available?
- Tbenson1
Props are gone. Still have the shafts struts and all that.
- Above Water
- Vessel Info: 1996 Carver 355
Long shot, it’s been a while but do you still have these shafts?
And the couplers are there too? Do you happen to know the size bolts for the coupler connection to the trans?
- Tbenson1
Above Water wrote:Qr Bbpost Long shot, it’s been a while but do you still have these shafts?
I actually do have the shafts. The props are gone. Have the struts and couplers and everything BUT the props that I sold on ebay. I'm trying to PM you now. I never get on here.
