Replacement Bilge Pump
jecaperton
Vessel Info: 1999 450 Voyager Pilothouse
Been thanked: 3 times
Post by jecaperton »
Hey all, I have two (fore and Midships) bilge pumps that I think are dead. With spring here and summer on its way, I want to be sure I have all of this critical equipment working. Have any of you replaced the 2000 GPM pumps? Is there a model you recommend? Is the Rule Mate 2000 GMP Automatic pump a good one?
Thanks all
Re: Replacement Bilge Pump
Post by g36 »
Have you verified they have power to them? Ot are they physically damaged? Rule makes lots of pumps. I don't have all in one Mine have separate float switches which is what usually will fail. Switches are cheap to replace
Been thanked: 285 times
Post by buster53 »
What have you done to make sure they are dead? I assume you have one aft as well. Is it working?
What ever happened with your water pump issue? Did you get that figured out?
Been thanked: 414 times
Post by Cooler »
Make sure the floats are not the actual problem. Those pumps are pretty bullet proof. A lift tech accidently flipped my switch to continuous run. Ran for 2 days. Still works. Original pumps from 1995. 8-) er
jecaperton
Thanks again, I have not laid eyes on it yet (weather here turned bad lately and the cockpit is way rainy) but figured I would ask first. This weekend is my day in the bilge.
As for the water pump, haven't gotten there yet either. As I am at the marina, I have shore water. I will be hopefully taking her out for a run this weekend after having my port exhaust manifold and turbo replaced. Both had cracks and were leaking coolant. Bummer there, but I knew it was coming from my survey.
I will definitely look at the pumps this weekend, seems as if I will have to make sure my plumbers crack is not showing :-P
Post by g36 »
good luck with no plumbers crack :beergood:
