Battery switch troubleshooting
- Thekaj
- Vessel Info: 1995 325 Aft Cabin
- Been thanked: 4 times
I plan on going back down with a multimeter to do a bit more scientific testing, but any thoughts on what the issue might be? It’s not exactly a complicated system. Besides the battery cables themselves, each battery pole has a voltmeter wire attached, and that’s it (bilge pumps attach at the batteries). Neither the mechanic nor I can see any odd bypassing going on. My only thought is that maybe someone mixed up the cables at some point and swapped one of the battery cables with the output. I just don’t know how that would still make “off” not work.
- Phrancus
- Has thanked: 16 times
- Been thanked: 133 times
- Contact:
Re: Battery switch troubleshooting
My approach would be to disconnect as much as you can and the build it up while double checking everything. I do that with a long wire into the engine room and check wire per wire for trouble. So first check if every cable is still a single connection (if there's a problem along the way from engine room to switch you want to know that early).
Then check the connections, you may have a 'bridge', an unwanted connection because of damage or a faulty device like an altnerator that shorts but in such a way that it still works.
Then start connecting batteries to engines to make them work, then you include the switch in the set up.
Note: do not disconnect batteries from the engine while running, this damages the alternator.
Tip: you might want to use a smaller, separate simple battery for testing and include a small fuse in the testing wire. So you don't work with the big amperages when testing and not damage anything when you short the cables by accident (get more fuses)
Tip: you might consider a small lamp (12v led or something) to use for testing. You can see it connect or not from a distance. Handy when you're in the engine room probing away and these modern meters often turn themselves off, or beep at strange moments and have displays that you can't read from where you are.
Last tip: make a drawing, a scheme so you know what you tested and also for future reference. Mark the cables at both ends and document it. Easier to ponder over while at a table and a coffee rather than having to remember it all while getting stressed out because the meter quit, the cables are too short, a connector you just tested turns out not to have connected after all and so on.
enjoy the search
- Has thanked: 457 times
- Been thanked: 1697 times
You need to confirm that your battery/source wires are hooked up to the source terminals on the switch and your load wire going to the breaker panel is hooked up to the load side of the switch. No wiring should be bridging the source and load terminals.
- Phrancus
- Contact:
You may very well have taken the effort of switching off and on dilligently when leaving and entering the boat while in the meantime there was a permanent connection....
