Weird Control Console Question
- Mungo
- Vessel Info: 1988 Carver Santego 27'
- Has thanked: 6 times
Anyone?
- Been thanked: 1043 times
Re: Weird Control Console Question
- Mungo
m
- Mungo
- tml1093
- Vessel Info: 1990 Carver 3807
I am hopeful for success.
- Mungo
A momentary with with center off but where you can push to one side or the other, is used for dual gas tanks
A non-momentary with center off would be used for a voltmeter to select which battery (1 or 2)
A non-momentary three position switch would be used for navigation and anchor lights (anchor, off, nav)
For fuses, a 20 amp fuse likely indicates blowers, a 10 amp is likely bilge pump and a 5 would be appropriate for lights
The colored wiring you show in the engine compartment looks like trim tab wiring... similar colors and it's twisted like shown towards the left side of that pic. I'd bet those go to the trim tab pushbuttons under the starboard panel.
If you lift the panels and make note of the colors of the wires connected to each switch, that also could help narrow it down.
- Has thanked: 324 times
- Been thanked: 595 times
Repowering the boat will more than likely cost more than the boats value.
- Has thanked: 455 times
- Been thanked: 1671 times
Users browsing this forum: paulr and 33 guests
