2002 Carver 506 Refrigerator Parts
bandersen55
Vessel Info: 2002 Carver 506
Has thanked: 8 times
Post by bandersen55 »
I own a 2002 506. I believe it has the original refrigerators. They work fine but many of the brackets on the door shelves have broken. Does anyone have a lead on where I might get replacement brackets?
Thanks,
Brian
2002 Carver 506
Lake Powell
Re: 2002 Carver 506 Refrigerator Parts
What kind of fridge is it? There is usually a label inside the fridge with the make and model.
I have a bunch of parts from various NorCold fridges. Take some pics of what's broke and post them.
bandersen55
Thanks for the reply. I meant to take some pictures, but forgot. I’ll do so the next time I’m on the boat.
2002 Carver 506
Lake Powell
bandersen55
The refrigerator is a Marvel and I need the brackets on the door that hold the bars in. I've attached pictures of them. I could also use the brackets that hold the doors shut.
2002 Carver 506
Lake Powell
Carpediem
Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
Been thanked: 25 times
Post by Carpediem »
I think I've got the same fridge but with wood grain. The plastic locks broke so someone put hooks to hold the doors closed while under weigh. I have wood grain panels in mine but want to replace with SS like yo have. Ill be following as I do have a couple of the rails on the doors about to give up.
Carpe Diem
Try to only boat where ducks don't walk
Seems like you could just cut a piece of aluminum stock to length and use two-sided tape to "fix" the brackets for the door shelves.
