Need to repair or replace DC Amps meter
BarryK
Vessel Info: 1990 Santego 3467
Twin 454 Crusaders
Has thanked: 12 times
Been thanked: 6 times
Postby BarryK » May 13th, 2021, 7:11 pm
Hi all,
The DC amps meter on my panel is not working, the needle stays fixed in position at about 30 amps. How to I open the panel to remove the gauge? Where can I buy a replacement?
Thanks,
Barry
Been thanked: 621 times
Re: Need to repair or replace DC Amps meter
Postby g36 » May 13th, 2021, 10:16 pm
Looks like it's hinged at the bottom but to start I would remove the screws around the perimeter of the panel starting at the top and work toward bottom checking as you go before removing the bottom ones to see if it tilts out. The meter may have a manufacturer sticker on the back but if its oem you probably will not find an exact match but probably easy enough to find the same size one.
Been thanked: 262 times
Postby buster53 » May 13th, 2021, 10:37 pm
Hate to say this...
Unplug from shore power and turn off your batteries first.
Has thanked: 457 times
Been thanked: 1697 times
Postby Viper » May 14th, 2021, 7:40 am
Check out the measurements on these Barry and compare....
https://www.amazon.com/Analog-Panel-Meter-Current-Ammeter/dp/B00A4TQY02/ref=sr_1_6?dchild=1&keywords=dc+panel+amp+meter&qid=1620992322&sr=8-6
There's also digital units that give you some other useful information. I'm replacing all of my analog meters with digital ones. Some AC ones for example give you hertz which is good to know especially when you're running your generator or you suspect there's a marina or utility problem.
Has thanked: 585 times
Been thanked: 1231 times
Postby bud37 » May 14th, 2021, 4:36 pm
Blue Sea Systems has lots of marine stuff....maybe they will have one to match up with your old.
Postby Viper » May 15th, 2021, 9:13 am
Barry, you can also contact Carver with your hull number and ask for the panel manufacturer info. They can also supply you with the part number for the panel which will help them narrow down the model. Hopefully the manufacturer still exists or has changed hands and the new owners have kept all the records.
BarryK
Twin 454 Crusaders
Postby BarryK » May 18th, 2021, 1:11 am
I was at the boat yesterday, the panel is definitely hinged at the bottom. I did not have a chance to work on it but at least I know how to open it!
Thanks again.
