1995 Carver 330 Mariner Transom Door Hinges
- stevwood
I have exhaustively searched for replacement aft transom door hinges (2) without success. They appear to be double offset "L" hinges with 3 holes with middlle hole offset by 2 inches. Dimensions are 3.75 tall by 1.375 wide per hinge side or 2.75 total width. I suppose I might have to order a custom blank hinge and drill the holes myself? Thank for any resources one could contribute to this ongoing search. Steve
Re: 1995 Carver 330 Mariner Transom Door Hinges
Could the stock hinges you have be repaired .....maybe new pin, replated etc.......
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Do you have a part#? Carver used standard manufacturers for hardware, so they should be available somewhere. I will check on mine and see if I can identify something. They are probably Attwood or Perko. Check the back plate on the current hinges for stamped number.
er
Steve, contact Carver with your hull number. Carver may still have it in stock. Failing that, they'll be able to tell you who the supplier was and their part number.
- Raggedy Hobo
- Vessel Info: 1996 Carver 330 Mariner
- Been thanked: 2 times
Mine upper was bended due to someone heavy was sitting on the door. Hammer helped-just du it on the dock
Baltimore, MD
