Have a 56 Voyager, and our Malber washing machine no longer spins out all the water. Since the boat is a 2005, was looking to replace it. Can find replacements that fit the demensions of the Malber but not able to fit thru the stateroom door. Has anyone replaced a washer and or dryer on this boat and have any suggestions?
Thanks in advance.
Malber Washing Machine Needs to Be Replaced
- SoundTraveler
- Vessel Info: 2005 56 Carver Voyager
Re: Malber Washing Machine Needs to Be Replaced
Welcome aboard. Does the doorway have a frame around it that can be removed? I was in the same situation before on another boat and removing a door frame solved the problem. Also look at removing the washer's shell to make it smaller.
