83 3207 Aft cabin
dmancinelli
Vessel Info: 83 3207 aft cabin
83 33 mariner
83 3207 Aft cabin
Postby dmancinelli » June 13th, 2021, 1:46 pm
Does anyone know where to get the vinyl type textured wall covering from an 83 3207 Aft Cabin?
Vessel Info: 2022 Stingray 182 SC
Been thanked: 467 times
Re: 83 3207 Aft cabin
Postby RGrew176 » June 14th, 2021, 7:53 am
Welcome Aboard. Sorry I do not have an answer to your question but someone here will be able to assist.
quickdecision
Vessel Info: Carver 3807, 1987
Been thanked: 23 times
Postby quickdecision » June 14th, 2021, 9:57 am
dmancinelli
You will need to remove old vinyl first, suggest you use a multi tool, the old glue will cut quickly. Try not to damage vinyl during removal, you can use this a template for laying out new one. Once old vinyl is removed, if the raw fiberglass surface is lumpy with imperfections, hit the high spots with a sander using 60 grit. Next, in order to hide transfer, I suggest 1/4" foam backed vinyl, this helps to prevent transfer of hull imperfections. Only use 3 M adhesive spray, recommend watching You tube video if you have never done this job before. 3 M adhesive remover for clean up. Last you will need to add some kind of teak trim to hide vinyl joints. For vinyl, Joann Fabrics, Marine connection Ft. Pierce, or local supplier in your area. Find supplier that has seconds in wide rolls, Bolts come 54" wide. Best price I have found, depending yardage purchased, $ 5/7 per lineal ft. This is not a hard job to do. The end results are worth the effort. To job this out would be 15/20 grand for a 35'/45' boat. Make sure you buy enough to handle entire project, color match will be very hard to replicate.
Ron
Has thanked: 53 times
Been thanked: 426 times
Postby waybomb » June 14th, 2021, 12:18 pm
Welcome aboard!
dmancinelli
83 33 mariner
Postby dmancinelli » June 15th, 2021, 5:41 pm
Thank You
Has thanked: 455 times
Been thanked: 1671 times
Postby Viper » June 16th, 2021, 6:47 am
Welcome aboard.
Carver may still have info for your vintage. Contact them with your hull number and they may be able to give you supplier information and the part number for the vinyl used in your build.
Users browsing this forum: No registered users and 62 guests
