Steering question
Roddono
Vessel Info: 1991 Carver 33 Aft Cabin
Has thanked: 26 times
Steering question
Postby Roddono » June 20th, 2021, 8:42 am
Dumb question. I have a 1991 Carver 33 aft cabin with dual helm.
How do I tell if it has hydraulic steering or mechanical? If hydraulic does nobody know where the reservoir might be located. Upper wheel seem stiff.
Thank.
Ray…
Been thanked: 615 times
Re: Steering question
Postby g36 » June 20th, 2021, 8:53 am
Hydraulic will have a fill cap on it right on top behind the steering wheel where it's mounted. There will be one at each driving station This is also the helm pump, purging air will consist of turning the steering wheel back and forth the system will then purge any remaining air. Heres a article I found that might help you understand and how to refill .https://www.boatingmag.com/how-to/how-t ... -steering/
Roddono
Postby Roddono » June 20th, 2021, 9:14 am
g36 wrote:Source of the post Hydraulic will have a fill cap on it right on top behind the steering wheel where it's mounted. There will be one at each driving station This is also the helm pump, purging air will consist of turning the steering wheel back and forth the system will then purge any remaining air. Heres a article I found that might help you understand and how to refill .https://www.boatingmag.com/how-to/how-t ... -steering/
So no fill cap on steering wheel = no hydraulic steering? I don’t have a cap. My old Chris Craft did as I recall in that location. Anyway, thanks for the quick education, I appreciate it.
Ray.
Been thanked: 1043 times
Postby km1125 » June 20th, 2021, 9:23 am
Roddono wrote:Source of the post
Ray.
It depends on the system you have. If you have Hynautic brand, then the reservoir is likely near the transom somewhere, probably close to the rudders. Hynautics are a pressurized system and have a reservoir. There will be a gauge on it showing how much pressure is in the system.
I'd bet your system is hydraulic, given the size, vintage, dual station and that it's a Carver
If the lower wheel turns when the upper wheel turns (or vice-versa), then it's mechanical.
Has thanked: 455 times
Been thanked: 1671 times
Postby Viper » June 20th, 2021, 9:52 am
Even a pressurized Hynautic system usually has a fill port on the helm, it's just not where you top up the system from, and the cap is usually on there really tight to deter easy removal in case the system is still pressurized.
I would also think that it's a hydraulic system for that vintage, especially with dual stations.
Roddono wrote:Source of the post.....So no fill cap on steering wheel = no hydraulic steering?....
Not necessarily Ray, some helms can be mounted behind the dash so you don't actually see the helm/pump. In those non pressurized cases, there is a remote fill port located on the dash somewhere.
km1125 wrote:Source of the post ....If the lower wheel turns when the upper wheel turns (or vice-versa), then it's mechanical.
Agreed
Roddono
Postby Roddono » June 20th, 2021, 11:17 am
Thank you all. Will get back to post when I do some troubleshooting
Users browsing this forum: No registered users and 92 guests
