Dehumidifier for 2000 396 Aft Cabin
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 23 times
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Dehumidifier for 2000 396 Aft Cabin
- Been thanked: 615 times
- tgebler
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
https://www.amazon.com/gp/product/B081RG8JYR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It's been very hot and humid here the last three weeks. Our marina doesn't allow air to run if you aren't there so my boat was getting up to 115 inside. It has also been very humid with dewpoints in the 70s. I've been using it all spring with good results.
When we are on the boat I set this under the dinette and let the tank fill up. Last weekend even with our air running I pulled a full tank out of the air in 12 hours. (super humid outside, then poured rain that morning).
When we leave I set it on the counter and let it drain into the sink.
We've noticed a difference in the air quality when we walk in. We have some air handling challenges but it's more due to poor design than anything else. Whomever decided to install the AC units so they would suck in bilge air and not cabin air should be sent back to engineering class. I've sort of solved those problems with some canvas inserts, but that's a problem I need to really solve in order to get my air issues fixed. (sorry for the rant... buy a dehumidifier...it's worth it)
- vineyardgray
- Captain
- Has thanked: 125 times
- Been thanked: 32 times
- Contact:
https://ecor-pro.com/best-boat-dehumidifier/
Not cheap but works perfectly and no water buckets to empty regularly or hoses to plumb. I did not buy a stainless unit as it was even more expensive and I'm not in salt water. I bought this one specifically:
https://ecor-pro.com/product/epd50-dryf ... umidifier/
For right now, it is "installed" in my head and blows dry air into my cabin; the damp air discharges through the head window. I plan to install it properly in the cabin closet and plumb an exterior vent for the damp air and an interior vent for the dry. The unit is quite compact. Eventually, I will install wiring to run the unit from my ac/heat thermostat from the humidity control contacts.
My boat gets gross damp when the seasons start changing - hot in the day, cool at night - the humidity hits the roof and sleeping becomes a very uncomfortable affair. This solved the issue entirely and has extended the season for me.
1988 Carver
3867 Santego
PCYC
- mjk1040
- Been thanked: 242 times
