PVC Vinyl flooring on decks CPMY 390
Sailor Robbert
Vessel Info: Carver 390 CPMY 1993 with 250 HP
Cummins Diesel
Has thanked: 19 times
Been thanked: 11 times
Post by Sailor Robbert »
Hi Guys,
This was a project that I did 2 years ago and was actually a trial, I bought 2 mm thick PVC Vinyl flooring and glued this on my decks with carpet water proof glue.
Now 2 winters later the vinyl is still intact and doesn't come loose at all. It gives a real authentic look and is easy to clean.
I'm glad I took the chance and enjoy it every day I'm on the ship.
Carpe Diem :pirate: :captain: ;-)
Re: PVC Vinyl flooring on decks CPMY 390
Looks great :down: What's the product and where did you get it? I'm sure others would like the info.
Sailor Robbert
Cummins Diesel
Hi Viper,
I bought this in the Netherlands on an internet site. This is actually a carpet that you would buy for the house. You buy it off the roll. Only this type is special made for marine purpose.
Have a look on the site, the product is called Teak nauticfloor.
www.internetloods.nl
Regards Robbert
Nice. Thanks for posting that. :down: Wonder if there is a North American distributor
Post by g36 »
Looks like you did a nice install job. :down:
PossiblyPaul
Vessel Info: Hornbill III
1988 Carver 2827 Voyager,Volvo Penta TAMD31 engines.
Ardglass Marina, County Down
Has thanked: 48 times
Been thanked: 6 times
Post by PossiblyPaul »
Good job. I did something similar inside my Fisher25 some years ago, but with a cheap 'non-slip' vinyl bought from a local carpet shop (off-cuts, too, cost about £15). I've wanted to do something with the cockpit decks on my 2827, looking at the same sort of material, as the bare white of the covers is a bit off-putting. Unfortunately, it would add to the already considerable weight of the things, which I already find something of a burden. Got to be done, though; perhaps artificial grass? :beergood:
Funga Safari
