Carver 530 engine removal
- aussie530carver
- Vessel Info: 1999 Carver 530 pilothouse
- Has thanked: 1 time
Hi all new member here.. i have a 1999 Carver 530 and the port engine has overheated and Cummins has stated it has to be removed to be rebuilt.... so how is this achieved.. does the galley have to be removed... has anyone on here attempted this.. any help would be greatly appreciated ...Regards Paul
- Carpediem
- Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
- Has thanked: 2 times
- Been thanked: 25 times
Re: Carver 530 engine removal
I have no first hand knowledge but depending on the extent of the repair they are doing I would think it could be done in-situ. Many large boats have the engine installed in such a manner that the oil pan can be removed and major engine work done with out removal. If the Cummins repair center is not local they may not be in a position to do the rebuild at the dock so they would want to have the entire engine taken to their facility. Removing it would entail gutting the salon and removing the floor structure as I do not believe there are engine hatches installed. I know that is the case on my 506. Good luck with the repair. We were interested in a 530 that had a failed aftercooler on a sea trial and the engine was repaired and the boat was back on the market in a very short time so I bet it was done in place.
Try to only boat where ducks don't walk
- glynnalan
- Vessel Info: 2000 Carver 530 Voyager Pilothouse
"Tina Marina" - Location: Henderson NV
- Has thanked: 5 times
- Been thanked: 3 times
I'm going thru this now. my starboard engine needs to be overhauled. i have a cummins tech coming in from CA tomorrow to come up with a plan to rebuild inside the engine room. How did yours come out?
