Carver 3326
- TimMN
- Vessel Info: 1980 Carver 3326
Carver 3326
Just picked up a 1980 Carver 3326. What engines did Thea e come with? They look like a Ford engine? Got it for next to nothing but the starboard engine over heats at higher speed. At idle in the slip it is ok.
Re: Carver 3326
If the distributer is in the front of the engine its a ford 302 or 351. If its at the back on the engine its a chevy 305 or 350.
in 1980, it could be any of the above.
The first thing I would do is replace your raw water impeller.
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Re: Carver 3326
I would also replace the thermostat. If the original bowl type stat is in there, it could be clogged up with rust.
er
erCooler By The Lake
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Carver 3326
Just as important as who made the block…what brand is the engine? Mercruiser, Volvo, Crusader, etc. I’m guessing, most likely, Mercruiser.
Re: Carver 3326
Did you figure our what you have? Inquiring minds want to know! Are they black, blue, red, dark grey??
