Riser replacement intervals
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 190 times
Tony
- buster53
- Been thanked: 261 times
Re: Riser replacement intervals
So where do you use your boat? Fresh, salt, brackish? How often do you flush the engine? How often should you change the risers? Could be as short as 3 years or could be easily 10 years.
It’s not really an hour thing…more like a calendar issue.
- tonyiiiafl
- Has thanked: 455 times
- Been thanked: 1671 times
Users browsing this forum: No registered users and 122 guests
