Prop Shaft Problem
Topic author
mikekomm
Vessel Info: 1989 4207
Prop Shaft Problem
Postby mikekomm » January 4th, 2014, 5:00 pm
We just purchased (escrow closes next week) a 1989 Carver 4207 that has a loose nut on the transmission end of the port prop shaft. We are taking possession of the boat next week and moving it to a new marina. Assuming that the taper / keyway has not been damaged from the loose nut condition, we are hoping that we can split the coupling open and just tighten the nut on the end of the shaft and avoid having to have the boat hauled out of the water and the shaft removed. Our boat has Cat 3208's and Twin Disc 507's. We don't have access to the boat now to determine if there is enough room in the engine compartment to open up the coupling and slide it down the prop shaft far enough to be able to get a socket on the shaft nut to tighten it. I'm hoping that someone with this same model boat knows whether or not there is enough room to do this.
Ramsport47
Been thanked: 57 times
Re: Prop Shaft Problem
Postby Ramsport47 » January 4th, 2014, 6:38 pm
It's been a while since I've been in a 4207 engine compartment, but if memory serves, there should be plenty of room to split that apart and tighten the nut. The only thing I would see as an issue is getting a socket thin walled enough to fit. We always seem to have to have the outside turned down
Kenny
T-Merc 350 Mag MPI (300hp)
Users browsing this forum: No registered users and 70 guests
