455 Bunk Bed supports
KnotSure
Vessel Info: 1996 Carver 455
Post by KnotSure »
So among the many things I've discovered in my first month of ownership is that when the previous owner redid the flooring he evidently removed/covered the receivers for the poles to hold up the upper bunk in the 3rd cabin. Does anyone have any pictures of what it SHOULD look like?
1996 455 "Knot Sure"
Eden Isle, La
Re: 455 Bunk Bed supports
This is from an ad for a 500cpmy....I think it is the same as yours just has the bit added to the stern.......can't see the receivers though for the carpet......maybe if you get lucky you can find one with hard flooring......good luck
KnotSure
Post by KnotSure »
That's it, at least now I know how the arms go!
Eden Isle, La
