Hello.
Newly purchased 2004 564 with non-functioning fan in master stateroom head.
Does anyone know where the fan is located?
Thank You.
Carver 564 Head Exhaust Fan Location
- pdev1234
- Vessel Info: 2004 564 Hardtop
- Walt
- Vessel Info: 1994 Carver Santego 380
454 Crusader XL
Lake Ontario - Location: Toronto Canada
- Has thanked: 3 times
Re: Carver 564 Head Exhaust Fan Location
It should be a blower type fan located just inside the hull from where the thru hull vent hole is. mine is on starboard side about 3/4 of the way to stern. I have a 380 so it may be different location but you can check you manual for hull fittings diagram.
- Carpediem
- Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
- Has thanked: 2 times
- Been thanked: 25 times
I have a 506 and the master bath fan is on the wall behind the shower. Remove the towel rack unit on the back wall and it will be right there. The 564 is a 506 with a cockpit.
Carpe Diem
Carpe Diem
Try to only boat where ducks don't walk
