Fitted bed sheets
- DMcQuillan
- Vessel Info: 1989 Carver 3207 Aft Cabin
- Been thanked: 654 times
Re: Fitted bed sheets
I'm afraid these are going to have to be pretty much a custom job unless its pretty rectangle shaped and nothing strange cut our etc. . Carvers and other boats have all kinds of mattress shapes and sizes. It's not a terribly hard thing to have done you can use a old set of sheets and mark/cut them to form a pattern and have someone sew new sheet sets from your pattern. . You may google custom rv or marine interiors online companies and maybe even get lucky that someone may have made them in the past. and have the dimensions you have. Best of luck
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Just about every boat has different size (and shape) mattresses. If you want something off the shelf, measure your mattress and find the closest size you can get that is slightly larger. If you want exact fit, 99% sure you will have to have one custom made.
On the off chance there is something out there that is an exact fit, you might want to tell us what boat you have.
- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
I have used a twin fitted sheet and just tucked in the excess on the hull side.
