Hi Everyone
I have to change a starter on a 1990 crusader 454 7.4l starboard side
No numbers on starter to match up.
I have found starters that will fit...How do I know if it needs to be Counter Clockwise Rotation or clockwise
rotation?
Steve
crusader starter...counter clockwise rotation?
- Hudsteve
- Vessel Info: 32 Carver Montego 454 Michigan city Indiana
- ScottPDX
- Vessel Info: 1995 Carver 325 Aft Cabin with twin 5.7/350 CID Crusaders
Re: crusader starter...counter clockwise rotation?
If you can bump the starter and watch each motor, you may find they both turn the same way (left hand is standard). You might also talk to Arley, a super helpful Crusader distributor.
Arley
Trans Pacific Distributors
1941 Walters Ct.
Fairfield, Ca. 94533
Ph.707-426-6670
Arley
1941 Walters Ct.
Ph.707-426-6670
For that vintage, chances are one of your engines is a counter-rotator. In a straight shaft application it's typically on the starboard side. In a v-drive application, it could be port or starboard depending on whether it's output rotation is opposite to it's input.
- KandJ72
- Vessel Info: '76 Carver Mariner 3395
Twin 351W Vdrives
Refit in process - Location: Central NY
- Has thanked: 20 times
- Been thanked: 3 times
If you still have the engine tags on them you can decode it and it will tell you if it's Standard or Reverse.
You can also look at the timing marks on the engine to determine if they are counter-rotating or not.
Check the firing order around the dizzy cap.........standard 1,8,4,3,6,5,7,2...counter rotate 1,2,7,5,6,3,4,8....
- Hudsteve
