1988
- Vessel Info: 1984 Carver 3607 Aft Cabin
- Been thanked: 2 times
1988
Does anyone know the height with the bridge canvas removed? I need to get the height to get a shipping quote for a boat that I am considering purchasing
- Been thanked: 1043 times
Re: 1988
The specs say 11'9" without an arch or hardtop. However, if you're going to be piloting it, note that it doesn't leave much room for YOU or YOUR HEAD, since the highest point would be the railing around the bridge or the top of the bridge wheel.
- Phrancus
- Has thanked: 16 times
- Been thanked: 132 times
- Contact:
Re: 1988
I don't know the design our that particular boat but I remember that mine had to be decapitated a bit more by removing the splash guard to save a couple of inches.
Stupid enough I only leared much later how to emergency tilt the drives (hydraulics were out) so we could have saved ourselves a handfull of screws to remove and put back....
Re: 1988
- Has thanked: 579 times
- Been thanked: 1210 times
Re: 1988
- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
Re: 1988
- Phrancus
- Contact:
Re: 1988
bud37 wrote:Source of the post This won't solve anything BUT more of a statement......I just find it odd that after all these years of shipping boats all over there isn't some sort of shippers log or handbook on popular boat models for these guys as to heights and what to remove.....
there is a common denominator: the height of the bridges.
All boats are different, even if they were the same when they left with the same type designation from the factory. Yes, even at that moment they were probably not all equal. A type XYZ may very likely not have the measurements in the handbook as the owner added some stuff, the drives won't tilt up any more, there was an issue with the antenna and the radar dome was an optional.... but on this particular boat it was not equipped as removable because the first owner lived next to a huge lake without bridges between his house, the bbq sandbank and the marina gas station.
From the point of view of a transporter I too would give the sizes of the hole that boat has to be transported through and leave it to the owner to figure out what to to do to make it fit. After all, what's that owner going to do when there's a bridge over the water that will not flex to fit?
I would also add some information on the height of my trailers but even that may cause a discussion on what stand to use on that trailer.... if any.
How easy life must be when living where boats are built to ones liking (and budget), where no frost occurs and where maintenance parts and professionals are nearby.
And a good bar plus restaurant plus playground are next to the clubhouse of course.
Re: 1988
Phrancus wrote:Source of the post From the point of view of a transporter I too would give the sizes of the hole that boat has to be transported through and leave it to the owner to figure out what to to do to make it fit. After all, what's that owner going to do when there's a bridge over the water that will not flex to fit?
The shipper is responsible for the load at all times, just the law. Consider this, it is your business to ship boats, you get the contract to ship a fairly common Carver 3807, you have your height restrictions for the route etc......now you ship this boat successfully.....now if it was my business I would have logged exactly what height we ended up with and exactly how we got that and on what trailer, so the next time it is easy and not a lottery as to whether the customer can figure this out. .......so down the road a few thousand times you have a pretty good data log of different boats etc.
That was my point, it just seems like common sense if this is the business you are the expert in. Sure there will always be a first time but those will become fewer as time passes........just my opinion.
- Phrancus
- Contact:
Re: 1988
I'm always amazed how may different brands, types and variations on the same theme there are! And not just for motorboats, sailboats are even worse; seems like every one is a one-off!
Only thing in common are things like the head and the battery so it seems.
- Grafunkus
- Captain
Re: 1988
.bud37 wrote:Source of the post The shipper is responsible for the load at all times, just the law.
This is interesting. Our shipper required us to make sure the boat was at the correct height.
Users browsing this forum: No registered users and 44 guests
