Swimming at Anchor with Generator Running
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 22 times
Other than the water sports (skiing, knee board, wakeboard), One of the experiences we really enjoyed was to drop the anchor, open the ice chest, bring out the snacks, crank up the tunes (not so loud to annoy nearby boaters), and swim/relax in the water. Since at our age we have concluded, that water sports are a thing of the past and leave those activities to the kids and grands.
So here’s the question. What’s the best policy for swimming while at anchor with the generator running?
I’ve seen boaters doing this in fresh and saltwater, but the thought really never crossed my mind. I completely understand the “No Swimming Allowed” in marinas.
What are your thoughts?
What’s your policy as the Captain?
Where does the Genny exhaust come out on the 405/406 Aft Cabin?
Is there an electrical hazard similar to the swimming in the marina issue?
There’s obviously a load of knowledge on this forum and I’m soaking it all in! Trying to stay ahead of the “Learning Curve”!
EDIT: And then this popped up in a Google Search: https://newcontent.westmarine.com/conte ... lar_86.pdf
And another: https://uscgboating.org/library/boating ... _rev_a.pdf
1979 Caravelle 18’
- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
Re: Swimming at Anchor with Generator Running
- Has thanked: 270 times
- Been thanked: 1159 times
- Has thanked: 585 times
- Been thanked: 1231 times
So on the the electrical side, on board generators run at anchor will have any produced power run back to the generator.....but there can be a problem if you have a leaky appliance on board that leaks to the bonding system......it could under certain circumstances energize a thru hull, prop shaft etc....anything metal bonded to the system.....now if these were to be touched a swimmer could be paralyzed and be in trouble even though you are at anchor, now in salt water this is far less of a danger than in fresh water, but nevertheless awareness to these things is important in how you go forward running , maintaining and enjoying your boat.
FYI...poorly wired cheap inverters can create the same sort of issues.
It is nice to see you are taking the time to arm yourself with this info....good luck with your boat...
- Has thanked: 72 times
- Been thanked: 1054 times
The biggest risk is if you used an extension cord and ran it AWAY from the boat, or there was a risk that the cord end would end up in the water. THEN you'd have a current path from that extension cord back to the grounding system on the boat, through the water. That kind of thing would be dangerous for folks in the surrounding water.
I know a few folks who will run the generator while on the hook, usually so they can keep the air conditioning running. Depending on where the exhaust for the generator was, I may or may not be concerned. If it exited the stern then I'd probably shut it down while people were swimming or sitting on the swim platform. If it exited amidships I probably wouldn't shut it down.
- Has thanked: 457 times
- Been thanked: 1690 times
- Been thanked: 620 times
km1125 wrote:Source of the post You could never actually energize a thru-hull or prop shaft, as that would be a direct short back to the grounding system.
Unfortunately you can if the bonding system happens to be broken in the right place.....like I said in certain circumstances.....also consider if you are powering up a neighbouring rafted boat and they have leakage.......not worth it.....just shut it down while swimming like viper and his mates do. Never ASSUME.
- waybomb
- CYO Moderator
- Has thanked: 56 times
- Been thanked: 444 times
Turn off the genny while in the water.
