ignition alarm
rv53
Vessel Info: 1995 Carver Mariner 330
ignition alarm
Post by rv53 »
Hi all, Anyone know what the alarm system protects or what sensors are on a 1995 mariner 330 as far as engine goes? Thanks in advance for any replies.
Re: ignition alarm
Would probably help to list the engines make/model on the boat, as others might have the same engine but don't know what would have come on that particular boat.
rv53
Re: ignition alarm
Post by rv53 »
The engines are 5.7l crusaders. I would guess it monitors low oil pressure and high water temp but was wondering if it would monitor low water flow through the exhaust or low tranny fluid too.
Re: ignition alarm
Post by g36 »
I would venture as to not monitoring exhaust water flow/temp but that is a very easy add on. I've set mine up on my nmea network with temp sensors and alarm points or could be a stand alone alarm.
Re: ignition alarm
Post by tomschauer »
Low oil pressure, high engine temp and high transmission temp.
