355 aft head unit not filling
Boathooked
Post by Boathooked »
Anyone have any thoughts on why the aft head does not fill? I hit the fill side of the switch and nothing. The flush works as does the drain side of the fill/drain rocker switch.
Thanks!
Ramsport47
Been thanked: 59 times
Re: 355 aft head unit not filling
Post by Ramsport47 »
I'm thinking that you may have a faulty wire or switch, or maybe a wire fell off the switch. Best thing to do is pull the switch and test it with a volt meter. If the unit works on other settings, it is likely not the problem.
Kenny
T-Merc 350 Mag MPI (300hp)
Boathooked
Thanks Ramsport, I will check the switch and hope it is just that.
