Quick Tip: Cleaning a Crusader 6.0 Heat Exchanger
Delorean6855
Vessel Info: 2004 Mariner Three Sixty, Crusader 6.0s w/225 hours, Koehler 7_3e genset
Been thanked: 5 times
Post by Delorean6855 »
In case this helps someone else...probably would work for other HE's I'm sure.
My port engine was running a little hotter (pushing 180 degrees) at 3000 RPMs. Starboard was solid at 170 and change. I had already cleaned the SB heat exchanger so decided to do the port.
You can see there are some blocked tubes at the bottom. I had already started working down from the top using 1/8" brass spindles to break through the crust in the tubes and followed up with a wire brush. Works great. I used a shop vac with a detail attachment to suck out the debris as I went along.
New end cap gaskets with aviation gasket seal after scraping the surfaces and was good to go.
After cleaning, temps solid.
https://www.amazon.com/gp/product/B0102 ... UTF8&psc=1
https://www.amazon.com/gp/product/B08CB ... UTF8&psc=1
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 149 times
Re: Quick Tip: Cleaning a Crusader 6.0 Heat Exchanger
Post by KyleR »
Thanks for sharing!
A correct caliber gun cleaning kit also works great for cleaning tubes - and is a lot cheaper! :-D
MV Verity
2002 Carver 396
I have done that and found bits of plastic stuck in there, well worth the effort....good job .... :down:
Post by mjk1040 »
Have any of you tried RydLyme descaling?
