2007 Carver 560 Voyager:
I had an attempted break into the living room area of my boat resulting in the PORT SIDE CENTER PANEL of the tinted glass being shattered.
I can see the original manufacturer of glass was: TREND TEMPERED GLASS 05 [this panel measures 48" wide X 36" high] and does have a bottom to top arc.
Any assistance is greatly appreciated, even if it's a part number, source for this part, or possible cad type drawing of that panel would be a big help.
Replacement Center Cabin Glass Panel
- Joe Willie
- Vessel Info: 2007 Carver 560 Voyager
- Has thanked: 2 times
Re: Replacement Center Cabin Glass Panel
Welcome aboard. Sorry to hear about your misfortune. Did you try contacting Trend Marine? http://www.trendmarine.com/ They're in the UK but are a division of Taylor Made in the USA. They should have the specs, it just may take a little doing without the part number from Carver but with pics and measurements you may get lucky. Take a look at the panel and see if there is a part number of any sort. Look at the starboard panel for the info as well if there's nothing on the port one. At least they may have something to go on from that. It'll be pricey but they should be able to fabricate one. The alternative is to get a glazing company near you to try and fabricate a suitable replacement.
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Also, just in case you did not realize, Carver did provide a list of OEM parts used in the construction of your vessel. It should be included in the documentation folder that contains your manuals. These items usually stay with a model your size. You may want to take a good look through there during the off-season. Good luck!
er
- Joe Willie
Thank you to both of you, you are correct the OEM manufacturer is Trend Marine Glass out of the UK.
I'll reach out to them, see if that have or can fabricate a replacement panel.
