Hi everyone and Merry Christmas!!
sergei
Vessel Info: 400 Trojan Express 1998
Has thanked: 5 times
Post by sergei »
Hi everyone and Merry Christmas!! :captain2:
I purchased my 1998 Trojan 400 and have been repairing the engines / gearboxes since ((((
I have been looking for a detailed manual, specifically location of cables, routing of hoses etc as the generic manual has very little information.
Would appreciate your feedback. Thanks!
Re: Hi everyone and Merry Christmas!!
Welcome aboard!!
You're probably never going to find a detailed manual like that, but if you ask enough questions you might get the info you need.
Good luck on the project and post up some pics as you go along!
Been thanked: 414 times
Post by Cooler »
Welcome aboard! How are things there, because your now is our tomorrow. Hope that makes sense. The info you are looking for did not get published. ( cables & hoses ) Besides that, vessels manufactured for international delivery were often modified to conform to local regulation. Only way to be sure is to gain a clear understanding of how different cables and hoses are marked, and then attempt to follow through inspection via the various access plates. Not an easy job, but if you are skinny, and a practicing contortionist, it can be done. There is a guy in London who packs himself into a 24" square box, doing performances at the park where the London Eye is located. He could be a big help. Goodeye! 8-) er
Been thanked: 492 times
Post by waybomb »
Welcome aboard!
sergei
Post by sergei »
Hi guys, thanks everyone and hopefully you're enjoying your boats, while I have been only repairing mine.
I wasn't skinny in the beginning, but the more work I do by myself, the skinnier I get. And feeling older )))
Anyways, I'll get you posted with some pics, hopefully soon the boat will look almost like new.
BTW the prices here are an absolute nightmare, say for the new set of covers I had to fork out $14K AUD .
Here's a screenshot of mine
sergei
Post by sergei »
I'm sure you guys know a lot more than I, wanted to ask about a strange sound, which comes from around the shower area. It only happens when the boat is rocking at bigger waves along its longitudinal axis. It sounds as if there is something loose in some cavity and this relatively heavy object starts hitting the hull. Is it possible that there is some structural joint issue and a relative movement is causing this sound? Your advice is highly appreciated. Cheers
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Post by pepmyster »
Welcome!!!!!!!!!!!
sergei wrote:Qr Bbpost I'm sure you guys know a lot more than I, wanted to ask about a strange sound, which comes from around the shower area. It only happens when the boat is rocking at bigger waves along its longitudinal axis. It sounds as if there is something loose in some cavity and this relatively heavy object starts hitting the hull. Is it possible that there is some structural joint issue and a relative movement is causing this sound? Your advice is highly appreciated. Cheers
Is it possible it's just water hitting a part of the hull, perhaps a chine, at the same time? Several folks report issues with some extended swim platforms, or where the hull is "hollow" in the aft just ahead of the swim platform and when waves come in from the stern the whole wave "smacks" the underside of the platform or hull sounding like a hammer or a drum.
Post by Cooler »
My guess would be something like a hose or strapped cables came loose from a hanger along the hull. Those hangers were made from heavy duty zip tie straps. Maybe one or two dried out, creating some slack, so when the hull rolls in a wave, the bundle swings and hits inside hull on way back. I don't think it's a joint issue, but could be anything. The hull on those Trojans were built extremely strong. There was a guy who hit a 30 foot post that was penciled in Lake Michigan. He was at full plane at contact, and it shook the entire boat. He thought it may have done damage, but when we did a dive and inspected it, there was no damage at all. Just a minor rub in the bottom paint. When he lifted for the season, physical inspection confirmed our dive inspection. If you are really curious, drill a hole in the shower wall, and use a flexible pencil camera with light to peek around. Good luck. 8-) er
sergei
Post by sergei »
Thank you very much for sharing your thoughts! I did think of the peculiar water wave sound as I did hear it myself near the swim platform. And I thought I'll do a camera inspection using the existing holes - such as the shower downlight and the like. BTW there is some kind of screw on round plastic lid inside the cupboard in the shower / toilet - I presume it's an inspection hole? Will keep you posted if I find anything - this is not a priority - at the moment waiting for an overhauled engine to be put in - you would know the problems with Mercruisers sucking back some water from the risers under low revs - well, unfortunately i did get that - the valve stems got stuck, bent the pushrods and off we go ....
Cheers and have great time
