Introduction
Andrew225
Vessel Info: 1987 Carver Montego
Introduction
Post by Andrew225 »
Hi Everyone,
My Name is Andy, I just joined this group. I have a 1987 27' Carver Montego. I have owned it for a couple of years. I do have some maintenance issues that I could use some help addressing if anyone has any info. The Vacu flush seems to have lost is seal maybe. It has some backflow and when I pump it out I have to put a stopper in the toilet to create a vacuum for pump out.
Re: Introduction
You might want to check and make sure the vent for the waste tank is working correctly (not blocked).
Also, the vacu-flush systems do need the "duckbills" cleaned or replaced periodically to make sure it can properly build and hold a vacuum.
Been thanked: 492 times
Re: Introduction
Post by waybomb »
Welcome aboard!
Re: Introduction
Welcome aboard.
Ya check your tank vent to ensure it's not blocked in some way, either on the outside fitting or in the hose. If you haven't already, replace the duckbill valves (4) and by the sounds of it, you should replace the seal in the bowl as well. They're regular maintenance items that you should replace anyway. Test after these are replaced and go from there. If they don't solve the problem, further diagnosis is in order.
When your vacuum pump finishes cycling and shuts off, does it come back on again by itself a short time later?
Does water stay in your bowl between pump cycles? There should always be water in the bowl.
When you flush, does all the waste get cleared out?
Re: Introduction
Post by g36 »
Welcome. All good suggestions on the vacuflush maintance. You can download a manual for it and will help with part locations an part numbers for items you'll need for repair.
Re: Introduction
Post by RGrew176 »
Good luck and welcome aboard. Hope you have many fine adventures aboard your Carver.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Re: Introduction
Post by pepmyster »
Welcome to the group!
Blessed_C's
Vessel Info: 2000 530 Voyager with Cummins 6CTA8.3-M2
Re: Introduction
Post by Blessed_C's »
Just joined. Looking for help with parts.
Re: Introduction
Blessed_C's wrote:Qr Bbpost Just joined. Looking for help with parts.
Welcome aboard!
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Re: Introduction
Post by ColRon »
Welcome aboard!
Ron
“Escape Plan”
Murray, KY
:usa:
